Configure the Open Shortest Path First Version 3 (OSPFv3) instance on circuitless IP (CLIP) interfaces for the Global Router or a specific Virtual Router Forwarding (VRF) instance.
- Ensure the CLIP interface exists.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
You can also perform this configuration using Create an OSPF Interface on a CLIP.
- In the navigation pane, expand
- Select IPv6.
- Select the Circuitless IPv6 tab.
- Select a CLIP interface.
- Select OSPF.
- Select enabled.
- Select the ellipsis (...) to choose an area ID, and then select Ok.
- Select Apply.
OSPF Field Descriptions
Use the data in the following table to use the OSPF tab.
| Name | Description |
AdminStat |
Enables the OSPFv3 instance on the CLIP interface. |
AreaId |
Assigns an OSPF area to the OSPFv3 instance. |
